help, panic!
  • help, panic!
    Hi there. i live in a remote place and rely absolutely on my boat and motor. Also , at home, we have very little signal, so i may seem inattebtive getting back, if anyone can help. (I'm in a bigger island now , where there is a connection.)
    THE MOTOR..
    Yamaha 60 4-stroke, high thrust.
    3½years old
    1100 hrs, (so about 6 per week in three trips).
    ALL maintenance at correct intervals.
    Prop good.
    oils good, filter new
    fuel filters good.
    plugs all new.
    foot sound.
    tried replacing the gas, from a different source.
    THE PROBLEM..
    intermittent irregular juddering at 1200 rpm up.
    ONLY when in either gear, in neutral revs normally.
    Only revving to 3800 ish rpm when fault present .
    When fault not present revving to 5000..normal. (still a little irregular at low revs, say between 1000 and 250rpm)
    The signifcant things seems to me.
    ONLY manifest in gear..
    Only sometimes.
    Thanks. (sorry if i seem abrupt.. under a lot of pressure!)
    Don't know your model # but I would drain the VST and catch what comes out, specifically water.
    Part #13 is the drain screw in this model: http://www.boats.net/parts/search/Ya...201/parts.html
