Noticed this fuel slick immediately after cold start. Looked to be emanating from the exhaust. I couldn't tell if it was exiting as vapor or liquid before reaching sea water. Either way, it kinda concerned me. No signs or symptoms of any combustion issues while underway. Perhaps this slick represents fuel that was not ignited when I last ran engine on flush, which was 3 or 4 days ago. Any ideas, concerns, suggestions, etc?
Notice of Fuel Slick, Exhaust?
Your signature with engine info is now showing Jason.
As the engine seems to be running fine now, I'd keep an eye on it.
Perhaps check the spark plugs and the fuel pumps for slight leakage.
A failing fuel pump diaphragm may have seeped excess fuel into the crankcase and eventually into the water..
Originally posted by TownsendsFJR1300 View PostYour signature with engine info is now showing Jason.
Jason
Since it's a 2-stroke, especially an older one, I would think this is pretty normal, no? They're not exactly known for being "clean burning", after all. I've seen this on many of my/family's 2-strokes. I think it would also be normal to be in an overly rich condition when first starting a 2-stroke, too.Last edited by DennisG01; 01-09-2018, 07:48 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
I take it that you have not noticed this before? Perhaps your prop shaft seal could be leaking a small amount...not enough to drip on the ground but enough to see when you put it the water. Might want to have a quick look at that along with the other suggestions.
Originally posted by panasonic View PostI take it that you have not noticed this before? Perhaps your prop shaft seal could be leaking a small amount...not enough to drip on the ground but enough to see when you put it the water. Might want to have a quick look at that along with the other suggestions.Jason
Originally posted by 99yam40 View PostAll it takes is one cylinder not firing,burning the fuel running thru it to dump into the water to look like thatJason
You may be looking for an issue where there is none (see my post above). Sort as a tangent to this, what do your plugs look like? All similar and healthy?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostYou may be looking for an issue where there is none (see my post above). Sort as a tangent to this, what do your plugs look like? All similar and healthy?Jason
But... it's not about your engine being healthy or not. It's that ALL 2-strokes do what you are seeing. It's the nature of the beast. It's quite possible that the water conditions and sunlight conditions were such that it made the slick more noticeable. And, maybe it's been there before but you just weren't looking? Plus, think about what happens when you start up a cold engine... gotta prime it, right? That usually means a little extra fuel. The spark plug condition (color, etc) will tell more than just spark - it will tell HOW that cylinder is burning... meaning it's not just an "all or nothing" thing. If all look good and consistent, then it reassures you that everything is firing properly and could be chasing a non-existent issue.
This next comment does not negate gear oil leaking out, but do you have any water in the gear oil?Last edited by DennisG01; 01-10-2018, 06:23 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Â
