Hi all have installed new gauges in to the boat replacing the old that were added and unreadable . I have a Yamaha 115c 2stroke salt water series and the temp light blinks on the new gauge I have checked the dip switches at the back of the gauge and are all set correctly. once I connect the 2 grey cables in the motor cowling it goes into alarm ??????? also the trim gauge is suspect as i trim the motor up an inch it seems to to go nearly all the way up on the scale???????? as this is a common loom from gauges to motor could this be a contributing factor?? When I brought the gauges I also had to get an adaptor lead that would suit the new gauges to the old loom, and now the orange wire in the loom douse not connect in to the new gauge through the adaptor lead??
New style gauges replacing old
Does your tachometer have one four pin connector or two four pin connectors at the back? Here in the US a different part number is used for the multi-function tachometer. 6Y5-8350T-XX is what we use. Mostly.
Are you using an adapter harness between the tachometer and the trim/oil harness?
CETO indicates it is either a non US market engine or an early 1984 or so import.
what are the wire colors on the tach you are trying to use?
does this tach have 3 dip switchs under a rubber cap?
how many wire does the trim sender have?
does this engine have automatic oil injection?
Hey rodbolt17 yes it is an aus motor 1999. It has 3 dip switches on the back. See pic. I’m sure it is a two wire sender. If I put the old gauge back in the trim gauge works fine but with the new gauge the trim gauge seems to be way off. As I trim out the smallest bit the level climbs really fast compared to the old gauge. I have and adaptor harness to suit the new gauge to the old harness 6Y5-85335-10-00. Only once I disconnect the Grey bullet plugs on the back douse the temp gauge stop flashing and buzzer stops is this correct...
Yep, it is a 1999 model for the non-USA market. Equivalent of a US model S115TLRX or S115TXRX. http://www.boats.net/parts/search/Ya...XRX/parts.html
It uses a three wire sender. Not really compatible with the 6Y5-8350T-90 gauge which appears to be what you have. Reason being is that the -90 tachometer does not provide five volt power for the three wire sender. Which your model has.
Yes, the gray wire is disconnected. See diagram below. Also a note about the trim gauge. One clever fellow in your predicament reported that he bought a five volt power supply and used it to supply the sender with voltage.
Something like this I think.
https://www.ebay.com/i/131199957529?chn=ps
https://www.superbrightleds.com/more...CABEgL4DfD_BwE
Originally posted by jarrad sharp View PostIs there a way to trick the temp sender to trigger the alarm to test it is all ok with Grey wire disconnected???Last edited by boscoe99; 12-25-2017, 07:06 PM.
Originally posted by jarrad sharp View PostThe trim gauge works in 2 wire mode but not 3 wire is this due to the 5 volt problemLast edited by boscoe99; 12-25-2017, 11:24 PM.
ÂÂÂ
