hi everyone the problem can be so small and yet create such a big drama, i wasn't getting enough current into the coil ,so i went through the whole harness to rectify the fault ,only a little corrosion on the fly wheel trigger switch caused all these, then it wouldn't run so went through the compression ,it was all even , then i thought may be the fuel pressure ,it was all clear had enough pressure in the rails ,took the injector out tried it out its seized took all out sent it to the fuel injector service center came back today haven't installed it as yet but will keep you posted how it goes,
one word of advice to all those owning a four stroke dont keep them stored for long period of time ,it causes a nightmare.
