115 OB jet grease leak
  • 115 OB jet grease leak
    My year old 115/80 jet leaks a little grease out of the small hole on the starboard side of the jet housing. This is a 1/8 or smaller hole directly on the side of the jet housing opposite the grease fitting..Does not do it when I grease the fitting, just leaks out a little after running. I grease after every use. Overgrease?
    over greased.
    wont hurt anything.
    as long as the grease does not show water contamination your good.
