I checked my YAMAHA 6L5S017311 MALTA for compressioin. I get 4,5 Kg/cm2 warm engine, 4,8 Kg/cm2 cold engine. The unit is quite old, I don't extactly know it's life history.
Putting some engine oil inside the cylinder the compression reading (cold) rises to 9 Kg/cm2.
Which should be the correct reading ? Should I consider replacing the piston rings ?
Many thanks in advance
