Outboard that will not start in the water
  • Outboard that will not start in the water
    I have a 1995 200hp, had problems before starting, I cleaned and adjusted carbs according to the service manual. With the cups on in the yard the motor idles all day long, when I put it in the lake it idles for about 10sec then cuts off. After running the battery almost dead I took it back home in the yard and it idled with no issues. Is my motor allergic to the water?? Is this bad gas or electrical?? Thanks for the advice.....
    Back pressure having exhaust under water can cause this if you have low compression. Do a compression test.....
    Also, old fuel will be harder to ignite with the back pressure.
