Help me! 2002 OX66 Yamaha 200hp Fuel Injected
  • Help me! 2002 OX66 Yamaha 200hp Fuel Injected
    I'm having trouble with fuel system on my 2002 200hp Fuel injected OX66 Yamaha outboard motor. Model number SX200TXRB. Starving for fuel when it was running. It ran for a Lil while idling but when gave more throttle the motor stalled out and never would crank again . Got home changed fuel water separator and filter on motor. Nothing. Running Ethanol free fuel. Yes. Primer ball will not pump tight. Can someone lead me in right direction?!?
    if the primer has fuel in it but wont pump up tight at rest then most likely the fuel pumps are leaking or the VST needle is leaking.
    can you hear the electric fuel pump turn on for about 3 seconds at key on power?
      Only hear a click when turning key on doesn't sound like fuel is pumping to motor
