Anyone have any tips to modify a yamaha 200 hpdi to gain mph?
Yamaha modifications
Hydro Tec Marine Performance, INC
Exhaust tuners
Throttle bodies
Reeds
Engine mounts
Heads
Gear cases
Flywheel (rotor) modifications
Hydro Tec Marine
All is needed is money
and with all that, you MUST modify the ECU fuel and ign mapping.
its an air pump.
to make more power you need more air AND fuel.
all the mods above are designed to allow more AIR.
fuel is strictly con*****ed by the ECU and its already dirt lean on the HPDI.
I know they used to offer ECU's for the OX66 motors but I don't know about the HPDI.
myself I would sell the Z motor and find an OX66 to modify.
*** that kit is over 3000 dollars and good for less than about 50 hp and still no modified injectors,drivers or ECU.
if it was all that simple I doubt Yamaha would have developed the 3.3L hpdi.
the problem with increasing compression is anything over about 9.5/1 is going to require 97 octane or better fuel.
the issue with the HPDI is the higher the octane the slower the fuel burn.
on the HPDI fuel isn't injected until the piston has closed off both intake and exhaust ports.
by then there are only a limited amount of degrees of crank rotation to inject,fire and burn the mixture before the exhaust ports are open again.
ÂÂÂÂÂÂ
