Hi All,
Can somebody please help?
Motor is a 1999 Yamaha 130 BETO 205 hours on the clock. After fitting fuel pump kit, plugs, filters, thermostats, primer bulb and new fuel filter and fresh oil, it runs like a dream... I can ***** without any problems or I can go to WOT and it goes like a demon. BUT, if I go to WOT, after 10 seconds, the oil warning buzzer sounds, the motor goes into limp mode and the three indicators on the dash gauge flash, signifying that the engine oil tank is low.
I stopped immediately and checked the oil level in both engine oil tank and the motor mounted tank only to find it was full to the maximum mark on the tank. The remote tank had about 15 liters of oil in it. The motor heat felt normal and there was no overheat indication. I went back to port, removed the engine oil tank, cleaned it out, (no dirt in the filter), refitted the oil tank and checked the oil pump operation. It fills the engine tank to the mark and switches off. If I remove the sensor unit from the tank, it works correctly and sounds the buzzer at the low point.
It idles fine and gets out of the hole in about 2 secs, but if I go to WOT, after about 10 seconds, the oil indicators flash and it goes into to limp mode. The strange thing is that this only occurs if I exceed 5100 rpm. If if run it under 5000 rpm it will go fine all day but the problem remains!
Could this be something in the electrics? Sorry to be so long winded but I'm stumped!
Any advice would be much appreciated.
