2002 Yamaha Vmax OX66 225 Low RPM's at WOT - but running well?
  • 2002 Yamaha Vmax OX66 225 Low RPM's at WOT - but running well?
    I swapped at 1999 Mercury 225 EFI 3.0L to a 2002 Yamaha VMax 225 OX66 on my rig. Same boat, same height, same prop. The Mercury runs a 1.75/1 gear ratio and the Yamaha runs a 1.81/1 ratio. Mercury was turning 5800 rpm's at WOT and the Yamaha won't turn but 5400-5500. I would have expected the Yamaha to turn about 200 rpm's more than the Mercury based on the difference in gear ratios and it being the same setup.
    The Yamaha runs great, other than that, but its bugging me because the mechanic (and also Mark Croxton) said it should be turning up close to 6000 rpm based on setup (which would mean I needed to re-prop, I know).
    I have checked the hotfoot and the butterflies. Butterflies are about 5 degrees shy of dead horizontal at WOT. But, is that enough to knock 500 rpm's off the top?
    I also checked compression. #'s 1,2,3, and 4 are all 106-107 psi. #'s 5 and 6 are both reading 100 psi...which I don't understand. There is no evidence of any scuffing in the cylinders, so why are they both exactly the same but 5-7 lbs below the top 4 cylinders? Yamaha mechanic said that difference was within specs and would not cause the difference. He did say it probably could use a decarb. The motor has less than 200 hours on it and I have used ringfree in it since new. Any idea on the bottom 2 cylinders being lower but even with each other?
    Ok fellows. I need some advice on where to look for my rpms and why the difference in the bottom 2 cylinders.
    1. Low pressure fuel pumps?
    2. Decarb?
    3. Timing off a little?
    4. throttle body butterflies?
    5. ?????
    Thanks in advance for your help.
    ox66 250
    I have the same issues as above please help.i am going to put new head gaskets on just to look at everything .
      max RPM on the VX225 is 5500 RPM.
      the compression is normal, if you CC the heads you will find it.
      on the Yamaha compare cylinders in bank to bank.
      1-2 ,3-4 5-6.
      should be within ten PSI.
        Cylinders 5 and 6 have a lesser compression ratio than do cylinders 1 - 4. Therefore, it is completely normal to see less psi on the bottom two cylinders when a compression check is performed.
        1 - 4 have a 5.9/1 ratio. 5 and 6 are 5.7/1.
        For a Mercury to have more power than a Yamaha of the same HP would not surprise me at all.
          Check your muscles...
          How's the condition of your hull?
          I learned this one the hard way. Much to my chagrin.
          Boat came here to Atlantic side from the gulf coast and it began to loose power after about a week. Chased that thing for five hours over the next 3 days. When we pulled the boat out to bring it to our shop, the hull was fouled with Zebra muscles.
          Just sayin..
          If its got teats or tires, you bound to have trouble with it....
