A while back there was discussion about Yamaha recommending 20W40 grade oil for Southern warm water engines. Here is an excerpt from a Yamaha publication about E-10 fuels and it mentions 20W40 oil use.
...And speaking of oil changes, if you live in the southern region of the country—the hotter states—one of the things that Yamaha has recommended for four stroke outboard owners is going to a 20W/40 four stroke oil in their motor over the 10W/30 oil. The higher viscosity of the 20W/40 allows the engine to run cooler in those hotter regions of the United States.
So if you live in South Texas, Southern California, Baja, Southern Louisiana and Florida, you might want to remember that the 20W/40 oil is going to give you cooler engine temperatures when operating the outboard and also last longer than the 10W/40 oil. Since oil is essential to engine lubrication, you’ll also want to pay attention to the suggested oil change maintenance for your outboard and have it changed on time.
Yamaha Offers Help with Ethanol Fuels | Yamaha Outboards
