I have searched this forum and I have not found any help on draining old gas from my Hydra Sport 1800cc. I know this forum is exclusively for Yamaha outboards however I know there are some very knowledgeable folks here to help me solve my problem. I have approx. 1/4 tank of a 58 gallon tank and I already know there is some water in it because I unhooked the fuel supply line and got a lil water by using the primer bulb. But that's all I got..about a half cup of water then nothing.
i tried to put a hose in the tank but to no avail could I get gas..I think mainly because the hose curled up at the bottom of the tank and was sucking air. I tried to lower the trailer in hopes of letting the gas come forward to where the hose is located....still nothing. What other things can I try? I have a fuel filter(looks like oil filter on a car)...is there any way I could get gas pumped thru there? I also was wondering if I should just use some gas additive to dry up the gas and add fresh gas on top of the old...Any suggestions?
