I have a 4.2L 250 HP Yamaha with a Command Link Plus. Even though the Command Link Plus displays a water pressure gauge, the gauge is inoperable and does not include an indicating needle nor any other digital indicator. I am told I need to install a pressure sender to activate that feature. How difficult is it to install and connect the sender? Do I need to take the boat to a dealer or can an amateur install it?
Water Pressure reading
Does the install kit and T housing come with the sensor, or are they separate parts? If I proceed with this, I'd like to order all of the parts at the same time. Thanks,
Originally posted by wlewis11 View PostHow about wiring? Does it have to be tied into the main wiring harness?Last edited by tmann45; 07-20-2013, 01:03 PM.
Thanks for the info. I ordered the kit today. Boats.net parts rep didn't seem to think other parts are necessary. Rodbolt, do I need the T'stat housing too?Last edited by wlewis11; 07-22-2013, 09:28 PM.
Boscoe,
Please forgive me for my stupidity. After studying the diagrams, I have a few dumb questions, relative to the order in which your instructions are positioned after posting:
Is the "Optional equipment, Installing the isolator lead" an unrelated operation that just happens to be included on the same page?
If so, presumably, the highlighted "Installing of the water pressure sensor", Item #1, half way down the left column, is in reference to the diagram on the upper right side of page. Am I correct?
Is Item #4, the next to the last paragraph on right, in reference to the second from bottom diagram on left, and last paragraph on right, Item #5, in reference to bottom diagram on left?
Again, pardon my ignorance,
Walter
The optional isolator lead just happens to be on the same page. I knew that I should have erased that section, but didn't. I will do it now.
Yes, start at the part that says Installing the water pressure sensor that is highlighted in yellow.
There are two illustrations posted. Just follow them one thru six and they are in order. I am putting more space between them now.
We are all ignorant. We can't know it all. Best we can do is to keep learning.Last edited by boscoe99; 07-23-2013, 02:51 PM.
ÂÂÂÂÂÂÂÂ
