1994 225TXRS 2 stroke
I checked the TPS and from the readings in the 3.00 to 5.00 range I determined it was bad and ordered a new one.
Well I installed the new one and get the same readings as adjusting it with the two phillips screws does not help.
So I took it off and tried adjusting it by simply turning it with my fingers. I got the reading I wanted, 0.49 as the manual calls for a reading between 0.47 and 0.51.
I put two marks where the pin that goes through the rod is supposed to be. Now hopefully the pics show y'all the problem I am having with setting the TPS correctly.
Front view of bracket that was on boat when I bought it 3 years ago.
Side view showing the plastic piece with the notch that the TPS pops onto to.
Here is the problem. When I place the TPS in a position to where the pin can snap into the notch on the plastic piece, you can see how far off the screw holes are to bolt the TPS down.
Side view shows where the pin on the TPS is supposed to pop into the notch on the plastic piece. With it being so far off, the is no way to adjust the TPS to the specs the manual asks for when it is bolted properly in place.
Now I remember I had a problem two years ago when I rebuilt my carbs and tried to sync them according to the manual. I couldn't get the correct readings on the sensor. The motor ran and runs, but does act up a lot due to this. So this time while syncing the carbs, I decided to get the TPS set properly.
But now I am wondering at some point before I got the motor that someone might have put the wrong bracket on it?
I am going to try and secure it in the position that the reading on the fluke meter shows to be correct. Then go out and run it to see.
Does anyone know if it is even possible to put a wrong bracket on the motor?
Or what could possibly cause the readings to be so far out of specs that would cause the screw holes to not align up properly?
