Hose from top of engine
  • Hose from top of engine
    Yamaha 150 2 stroke 2004. Hard small hose from top of engine through into boat seems empty. What is it and where does it go?
    the only hose i know of that goes from the engine to the boat and is hard would be the speedo tube. and yes it will be empty.. air pressure from the water pressure makes the speedo work..
      hose
      Thank you, Couldn't figure out what it was for.
        actually coming from the top of the engine it could be a water pressure tube. is there a water pressure gauge on the boat..
          Yes there is and it works fine. Thanks for the tip.
            I'm getting ready to install a water pressure gauge system on a 2003 OX66 200 and wonder if there is a preferred way of routing the tube inside the engine cover? --Thanks!
              No special way just make sure it stays away from any thing hot..I have to replace a section on mine that got burnt. Just make it look neat and tie it away from any heat sources.
                actually, there is.
                water pressure should be tapped from the PORT head/block fitting.
