Need advice on rebuilding tilt trim on 1997 60hp 2 stroke
  • Need advice on rebuilding tilt trim on 1997 60hp 2 stroke
    1997 C60TLRV
    I opened up, removed and rebuilt the two lower shafts, no problem.
    If I support the motor in the up position and remove c-clip and drive out pin on top of the upper, single, larger piston, will there be enough room to pull out shaft assembly to replace seals if I hit the lower button and push down piston?
    Also is replacing the pump motor pretty easy?
    yes, just mount unit in vise wrapped in card board.take off the three alen screws and tap motor with plastic mallet and remove.might want to go to db electronics and take a look.good luck
      sorry i got ahead of my self. simply take unit shaft out at bottom of tilt assrmbly then swing it out and then take out top support pin..unit should come right out.happy days
