Oil transfer problem
  • Oil transfer problem
    Hi! I have a 2004 Yamaha 200 SW I bought a few months back. I have been having an oil transfer problem since I bought the boat. The engine will run fine for a while and then it loses high rpm because of the low oil level in the eng tank. I can turn switch to on position and manually fill tank with switch on back of motor. This is an occasional issue, once every so many hours after running fine. I do have a blinking icon on the lower part of my tach gauge though. After reading past forums of others whom have had same problem it appears it could be a number of things. I hope someone can advise me on a good starting point to resolve this issue. I dont want to have to pull off my cowling in the middle of a approaching storm or in rough water conditions due to this problem. Thanks and any advice will be appreciated. will be back tomorrow. unowedwho.
    remote tank oil level switch or wiring would be my guess.
    Should figure that out by reading the other threads on the subject like you said
