Good Evening Everyone,
Still newbie here and have a problem starting my port engine. Carbs are good, fuel supply appears good but need a suggestion to check for spark. On a car, I would pull the plug and plug back into boot and test to see if I have arch between plug and ground point on car engine....on the outboard, I'm hesitant to do this however. Is there another way you need to test it on an outboard?
I have plenty of crank, but it just won't fire (I'm being gentle to not over do it). I've tried using a spray bottle with gas in it in place of starter fluid and still no fire...thus I am at the point of testing for spark.
Thanks in advance,
Thanks in advance,
