2004 Yahama 150 2 stroke oil injection
  • 2004 Yahama 150 2 stroke oil injection
    Oil not pumping from lg tank to small underhood tank. I've checked the two fuses on the port side of engine and the appear ok. Changed the filter at the lg tank. Still no oil pumping up to sm tank even with the override switch. I finally pulled the lg tank and put 12 volts to the pump directly and the pump runs and pumps. Is there another fuse somewhere?
    Use the SEARCH function on this site as your oil transfer question has been brought up and discussed here almost every week or so for many years. You will find all kinds of information from previous posts.
      Thank you I'll try searching the site.
        keep searching, I have posted on this issue till my fingers bled.
        there is another website that still has my archives but its under simply. rodbolt
