2002 155 4 stroke
  • 2002 155 4 stroke
    I have a 2002 F115TLRA, 68V L 313981. Is their a fuel filter in front of the high pressure fuel pump or just the canister type in front of low pressure pump? My service manual does not show one. I have read about one at the VST. If there is how do I remove it?
    on your motor, no.
    the hp filter is inside the VST.
    requires intake manifold removal to access.
      Thank you I will proceed
