Oil pump
  • Oil pump
    My oil pump will not cycle on unless I do it manually. The float switch in the oil tank is working properly. The over ride switch works and fills the tank in a couple of minutes but, when left to work on its own it does not cycle on. Where can I find a schematic of the complete oil sensor and pump system?
    as you have no clue how the system works, a schematic wont help.
    do some searching on this site.
    I have posted my nads off on this issue.
    however as you posted there is a remote tank.
    narrows it down to 2 v4 systems or 1 of 5 v6 systems.
    need a model number.
