there are times when the motor will catch and start with the first turn of the key. Most of the time it wont start on the first turn of the key and then I have to give it some throttle and keep the starter engaged for a couple of seconds to get it to start and then the idle is really poor. I put it in gear and it runs perfect throughout the RPM range. A few months ago I used the info from this site to replace all filters; replaced both low pressure fuel pumps; replaced the "mystery" filter and pulled the injectors and had them serviced. That was all done for a different reason than the idling issue but I have had a problem with starting and idling before that. Compression is good; new ball installed; etc. Butterflies are clean and look good. VST looked clean when I was in it replacing the VST Filter. I know the fuel is good and have new plugs in it, etc. The last time anyone touched the linage etc was in Mar of 2010. I noticed the idling issue started in the winter of 2012. It hasn't gotten worse but it hasn't gotten better either.
CAn anyone explain the theory of operation and our what is going on from the time the key is turned on and engine starts? There are only two Yamaha mechanics within 75 miles of me. One almost cost me a power head and the other one is backed up for 5 weeks. Any help or ideas are welcomed.
THanks for the help!
