Was changing the water pump on my 98 Salt Water series II and looked at the seal/bearing under the steel plate. I cleaned it out a bit with a screwdriver and thought it was a shell piece but then noticed it was a few small pieces of metal. The drive shaft turns ok and no noise. Is that the bearing breaking up?
Bearing under water pump; metal pieces noted
The bearing is under the seal, so it's doubtful pieces of bearing could find their way up onto top of seal. Maybe metal pieces are from the water pump wear plate or other.....maybe if it's running fine then just clean it out real good and run it as it is....least that's what I'd be inclined to do....good luck!
This is a picture of the spring, does it look the right size? So does this require changing the seal only or the bearing also? That looks like a big job from what I've seen.
SR
The spring goes around the circumference of the seal lip to provide constant tension on the shaft sealing surface....sounds like a combination of wear,tear and maybe corrosion caused the spring to fail...as usual, Rodbolt hit it right on the head! Anyway, a seal replacement shouldn't break the bank, and it'll help keep water out of your lower unit!...good luck!
Â
