Last time out I was running 60 plus in my skeeter.
Motor is not set at right heighth 4.25 inches below pad. When I came off plane everything was fine no strang noises.
When I tried to accelerate or power load the boat on the trailer I had lost power couldn't power load or hopup on plane.
When I removed the cowling at home later. I noticed the wires and some plugs below the electronics had gotten wet.
Is this comon problem. (wet wires/no power)
Nothing else seemed out of the ordinary. I have not had it out since the water turned hard here in Michigan. What should I look for when I get it back it the water
