tilt end cap seals help removing tilt end cap and replacing seals but I need the end cap and don't see it listed on any parts lists, anyone know where to purchase the cap? I haven't pulled it apart yet and it looks corroded although it still works just fine I know it will have to be done. I ordered all the seals and a new trim motor cause it is real rusty and also still working good. Maybe I can pull off the whole unit and take off the main ram and send it to someone to rebuild it? It is a 2001 90hp tlrz 2 stroke. Also, a friend has a boat same year and his hasn't rusted at all and he said its because it has a Zink sacrifice annode? Is that something you add or is it already on the motor? Pic of cap attached.
Thanks, banjoman
Thanks, banjoman
