I have a pair of '03 250 HPDI motors on a boat in our shop that that will only run while cranking. They immediately shut down when the key switch is backed off to the run position. I have verified continuity at the key switch harness between the pink an red wires while the switch is in the run position. I have also verified continuity between the brown and red wires in crank position. The kill switch which is common to both motors has also checked out OK. I am really puzzled as to what possible common link these motors share that would cause this problem. Any suggestions? Thanks for your help.
Sam
Sam
