Water in Fuel
  • Water in Fuel
    What is the best way to get water out of your fuel system?
    I have already replaced the fuel filter.
    Water is heavier than gas and will go to bottom of gas tank, if you can get to the fuel sender you can remove it and put a piece of copper tubing on a hose and pump water off of bottom of tank and install a fuel/water separator filter to catch remainder.
