I have a 2001 Yamaha 50 h.p. motor that has a tilt problem.
It seems to work fine but recently it started to drop down very, very
slowly. In fact, you can hardly see it go down. I checked the fluid level
and tried to add some, but it seems to be full. So it must be a bleed down
from a cylinder? I assume the problem will only get worse.
To repair this do I need a O ring or two, or is there a full overhaul kit
available? Any help will be greatly appreciated.
MAKKY999
MAKKY999
