hellow all. im trying to find some one that might know about or have herd of this problem. on a 2004 200 hpdi o/b. is getting water in cylinders. starboard side. but more in the center cyl. i had a johnson v/6 that had this prob. found rotted out under exhaust cover . but took off cover on the yam and very clean in there. also changed head gasket and checked surfaces.very clean also . still gets water is this motor rotted or is there some outher way this can happen. thanks . r/t
need some advice
some advice
hi rodbolt17 and thank you for your reply. i know thay will corrode but were can i look between the banks not sure were you mean. the head looks very good had it off. are there any outher places to check alreddy took off exhaust cover very clean in there. i did notice exhaust leak under power head should i pull it to have a look.
Â
