since you guys were so helpful with my previous question i hope you can help me with this one.
2005 f115
my power trim makes a kind of crackling noise when i raise it from the lowest position using the single main piston rod. the double piston makes no noise. it has no trouble raising it just the noise. i greased the rods no change. this noise has occured since i bought the motor.
also, is it common to leak a tiny amount of oil around the seal of the trim rods?
thanks again guys!
2005 f115
thanks again guys!
