DT130TXRP PTT Parts
  • DT130TXRP PTT Parts
    I have a 1991 DT130TXRP with PTT issues. The trim cylinder end screw seals are leaking. So I was going to replace the screws, seals and orings. I ordered the replacement screws and other parts, but the new screws will not go over the piston sub assembly. The dealer insists he ordered the correct parts which it appears he did. Would anyone know why these screws will not go over the original pistons. I'd order the new pistons as well if I knew they would work.
    For this model I ordered the following screw part number:6G5-43821-01-00 .SCREW, TRIM CYLINDER END
    Does anyone have any thoughts? Did something change and I need to order the pistons as well.
    Any help would be appreciated.
    never saw a DT130, would love to see a picture.
    only twin rotating lower unit Yamaha I ever saw was a DX150.
    could you be reading the wrong model #?
      Ct130txrp
      Yep, typing way too fast. Thanks for catching this. It is a CT130TXRP.
        gotta see a picture of that one, a CT130 would be Commercial, T+four stroke,130 hp with trim, 25" shaft, remote control and a 1991.
        either the trim rod ends are deformed or someone has swapped the unit over time with another unit.
        or the wrong model number was used when looking up the parts.
