Ok,
I'm trying to work some kinks out of a 1990 Yamaha 40 that I recently got. Its oil injected, and after funning several full tanks of gas, the oil tank in the motor hasn't moved a bit. Is it normal to use almost NO oil after running at least 30 gallons of gas? I'm a little worried. Lately when the motor shuts off, it ****s to a stop with a bit of a squeak.
Probably a seperate problem, but when I 'gun it' out of the hole, sometimes the prop slips (like I broke the shear pin) and the engine screams and the boat don't go... But if I run it up smoothly, I dont have problems at all. Could I need to change the lower unit oil? I dont have a manual so I'm not quite sure how to check it? I see a screw on the lower unit. Do I open it up and see if oil comes out?!
Walter
Walter
