Hi,
Does anyone know of an easy way to check and adjust the ignition timing on a 1997 9.9 Yamaha? I've read the manual and it indicated that a dial indicator is used to determine the correct position of the #1 piston. Is there any other way that the timing could be adjusted without using a dial indicator?
Thanks for any replies and info. It is a 1997 9.9 MSHV.
Doneaster
Doneaster
