The outboard had water in the fuel. I cleaned all of the carbs and the fuel pump. I also replaced the starter assembly. The motor starts and runs when I have the red switch on emergency although will occasionally bog down. If I move the red switch to the normal the position, the motor will start but than quickly stall. Any ideas of what is causing this?
2008 Yamaha 90 hp Rough Running\Stalling
