Overheat indicating and oil level indication help?
  • Overheat indicating and oil level indication help?
    I have a 90 two stroke engine 2000 mod with this multifunction tach. Today I checked that this was correctly connected to the engine, that's right. However, two things I'm wondering:
    * Overheat display flashes all the time, what could this be? water jet is cool and nice, and the engine running at max speed. Not restriktet to 2000 rpm that user manual said under overheat conditions.
    * Oil tank is completely full, it should not then indicate the three fields on the tachometer oil tank is full?
