wiring in multifunction speedometer
  • wiring in multifunction speedometer
    I have a multifunction speedometer (6Y5-83500-A0-00) and i am asking which colored wire connected to the fuel sender. I have seen diagrams that a solid white is used and others that say use the white/blue wire. Which is correct? If I use the solid white then what is the white/blue used for? If I use the white/blue what is the solid white used for?
    Also can a GPS by used with this gauge to get speed instead of water pressure?
    thanks,
    GLS
    White wire is for USA style fuel senders. No can not connect to GPS for speed.
      this sounds like a dumb question but how do you tell which one I have? You said USA style. What other types are out there? This is on a 17ft Scout so is it safe to assume that it is a USA style? The white with blue strip is used for senders other than USA style?
      thanks,
      GLS
