best prop for F60
  • best prop for F60
    help is needed to find the best prop for F60 standard gearbox as it has a 13 pitch prop but difficulty getting on plane its hooked on to a caddy cabin aluminum 4.5meter boat any suggestion as i normally dont deal with small boats
    help appreciated
    Will need to prop to get at close to 6000 rpm's(high side of rpm range) to get most power when plaining off boat.
      you can look at this site and see if you can locate a set up close to what you are speaking of and see what prop they used.
      Performance Bulletins | Yamaha Outboards
