Does anyone know what the voltage output of the alternator coil is over the complete RPM range of the 15 HP 2 stroke?
According to my shop manual, with the regulator disconnected, and the meter set for DC volts, it should produce 12 V @1500 RPM. I would have expected it to produce an AC voltage so the meter should be set on AC volts. It doesn't say what the voltage should be at any speed above that. As the engine speed rises, I would expect the coil voltage to rise.
Also, the manual states that that with the meter set for DC volts, the output from the rectifier, or rectifier/regulator should be 13 volts at 1500 RPM. If the coil only produces 12 volts at 1500 RPM it is beyond me where the extra volt would come from.
