Hi,
Here is an unusual one.
At the end of last year my 2000 90TLRY got temporarily stuck in gear a few times - in both reverse and forward. I pulled the boat out of the water to investigate.
My first thought was that the gear shift until at the helm was stuck. But when I disconnected the shift cables at the engine the shift box moved freely. I reconnected the cables.
Second though was that the jam must be in the lower unit. Since I keep it in Cape Cod over the winter and it was late in the season, I removed the lower unit to take home and tear down over the winter. But, after the lower unit was off the engine, i tried the gear shift and it continued to be stuck. I again disconnected the cables and they moved freely. I tried to move the shift levers in the engine by hand and that narrowed the problem to the shift levers and/or shift rod in the engine. Both the levers on top within the lower cowl and the end of the rod underneath move slightly, but will are then jammed.
That got me thinking about what the cause might be - and I suspect a tiny screw that I dropped into the lower cowl 3 years ago when reinstalling my prime start module might have worked its way down into the hole that the rod goes through the cowl and has jammed things up. I could not find it after it dropped, and thought it really could not cause any harm. (I may be really wrong about that!)
To see what the real cause is will require removal of the shift levers and rod for inspection and to make sure that darned tiny screw is not in the hole. Since the linkage is located under the engine block, I am stumped as to how to remove them. My hope is that I do not have to pull the block out to get the linkage out!
The repair manuals don't address the linkage in text or in any schematics in detail - I can't figure out ow to remove & replace and there is very little room under the engine block. I may get some room if I pull the carbs.
Any suggestions from you folks as to how to disassemble and remove the shift linkage from the engine would very much be appreciated.
Thanks!
Thanks!
