[IMG][/IMG]Need a little Help! I just replaced a 1997 Yamaha 200 ProV with a #4 dead cyl,
With a 2000 200hp HPDI is the wire Harness the same as the 1997 motor?
The reason i am asking is because a have a extra Three wire plug..
Thanks,Frank
Yes wire harness are the same, can't tell by picture but if that connector is gray colored then its the diagnostic connector and should have a water proof cap on it.
