Greetings!
I need help with which parts I may need in order to rebuild my tilt assembly.
When I release the tilt switch (down) the engine continues to fall.
I assume the O rings (at least) need to be replaced, but in the components list it's difficult to tell what else I might need.
Any help you may suggest will be much appreciated! Thanks!
1992 P150TLRQ Yamaha Outboard POWER TRIM TILT ASSEMBLY
