6y5-8350t-82-00‎ multifunction
  • 6y5-8350t-82-00‎ multifunction
    I purchased a new T50TLR back in 2010. I would like to put a Multifunction Tach on my pedestal. Is the 6y5-8350t-82-00‎ the right one? What else will I need to buy to install it? Does the wire harness run from council to the engine or to several different areas?
    Thank you for your help.
    Flyboy26m
    it should work. Boats.net has a parts manual I dont here at the house.
    have you looked into command link,it has a ***** control as well for some models .
      Best to use 6YR-W0035-E2-00 Multifunction Tach Rig Kit for a 2010 model and it includes wiring harness needed to install.
        That would be a nice feature to have even on my sailboat.
        I show a number 6Y8-8350T-01-00 but I think that is just the Multi tach not the harness. $359 just for the Guage. $277.50 for the std guage with wire harness.
        Will have to do some more research on this.
        Thanks for the info.
          So this kit is everything including Multi Tech and harness.
          The other stuff like the trim sending units must already be in the engine.
          Looks like the way to go.
          Thanks!
            Yes trim sender is on engine.
            If you want the Command Link kit then use,
            Choice of
            6Y8-WE83S-70-00 Command Link square Tach rig kit
            6Y8-WE83R-60-00 Command Link round Tach rig kit
            will also need Main bus wire and pigtail bus wire runs about $140.00 depending on length needed.
              Choice of
              Is the $140.00 wire product needed on both kits or just the Command link kits.
              Is length based on battery to engine distance or Tach to engine?
              Can I wait and buy a control just for the RPM *****ing and skip the Command link?
              Regards,
              Michael
                The Main bus and Pigtail bus wire are for Command Link installation only, Main goes between hub at transom of boat to hub at console, need to measure that length. Pigtail bus wire go between hub at console to each gauge, available in 1, 2, 3 and 6 foot lengths.
                If want the ***** feature then will need Command Link gauge on remote control models or the new tiller handle models has it on handle.
                  if your not going to use the tri-ducer on the command link,skip the transom hub.
                  command link gives a lot more information than the digital 6y5.
                  with an optional sensor kit it can give hull speed and engine water pressure.
