Hello, I need a wiring diagram for the multifunction gauge. Mine seems to be different from the ones I have found here. I can't get the fuel gauge to work. I have a white w/blue stripe wire coming from the gauge which does not appear on any of the diagrams I can find. The gauge has 8Z2 on the back. Any assistance would be greatly appreciated. Everything else seems fine but I have not started the motor.
2000 ox66 250hp wiring diagram
I assumed these were the wires from the multifunction gauge to the fuel sending unit but I can't get it to work. I have two seperate fuel tanks. Both gauges worked last year. Neither work now. I am planning on using a switch to check each one individually.
Is there a different wiring diagram that shows the white wire w/blue stripe on the multifunction gauge?
ÂÂÂÂÂÂÂÂÂÂ
