Yam 150 trim tilt
  • Yam 150 trim tilt
    OK, I opened the reservoir and checked the fluid, then opened the bypass valve and raised and lowered the motor five times filling the rservoir each time. I raised it back up, and set it on the rest. I then cycled the trim rams and then set the motor on them and cycled it about half way up.. Now I cant get it to do anything. Could the pump or motor shaft be broken?
    Probably need to replace trim motor.
