yamaha T9.9MXHR shift rod replace question
  • yamaha T9.9MXHR shift rod replace question
    After removing and replacing the powerhead I found the shifting rod laying on the table. Do I need to remove the powerhead again to get that rod hooked back on up or can I rehook it from below?
    thank you
    I pulled the powerhead and attatched the rod like I figured I had to do.
    thanks
