Engine started running rough and quit. Restarted still ran rough at idle.Had good stream of water. Checked oil inject seemed ok.Checked compression bottom cyl. only had 40 psi.Also there was water in bottom cow.after oil inject test Engine had ran hot on last trip. I think head gasket is blown? Any other thoughts.
yamaha 04 tlrc90 dead cyl.
If fuel pump leaks into #3 through pulse port it can wash the oil off and cause major problems.
If cylinder is running lean fuel/air mix it can damage things also
Over heat can damage piston
All you can do is open it up and have a look to see what has happend
Originally posted by cgj13579 View PostEngine started running rough and quit. Restarted still ran rough at idle.Had good stream of water. Checked oil inject seemed ok.Checked compression bottom cyl. only had 40 psi.Also there was water in bottom cow.after oil inject test Engine had ran hot on last trip. I think head gasket is blown? Any other thoughts.
ÂÂÂ
