Bad Tilt/Trim Switch relpacement on 6x3
  • Bad Tilt/Trim Switch relpacement on 6x3
    Completely new to boating world and have a bad T/T switch but my question is how do you remove the Thruster housing to access the switch? Thanks
    remove the center handle cover,remove the screws or the 12mm hex bolt.
    remove the handle.
    typically switch replacement also requires removing the control box to properly wrap the wires.
    I hate flush mount boxes .
