help
  • help
    i have2013 yamaha 115 4 storke. i install a lowrance hds 7 lowrance 120-37 cable all gauges work but the trim gauges lowrence said see yamaha dealer dealer can not fix it dealer called yamaha said see lowrance can you help
    On the motor wire harness there is a pink wire wrapped with yellow or white tape, remove the tape and connect the two pink wires togather.
