Ignition problem
  • Ignition problem
    I have a Yamaha F 40 TLRX outboard. It is running on only 2 cylinders, 1 and 4 are dead. I have swapped the coil packs and replaced the CDI box but the problem remains with cylinders 1 and 4. Any thoughts?
    Use a peak reading voltmeter and test stator output to CDI and CDI output to coils. Post test results.
      Thanks I will do that ASAP
